Siebel Pricing Administration Guide > Creating and Assigning Rate Lists > Copying and Modifying a Rate ListAfter creating a rate list, you can copy and modify it to create a new rate list for different types of customers or markets. For example, you might use a rate list named United States Rate List as the starting basis for creating new rate lists for different countries. First, copy the rate list. This retains the original rate list and creates a new rate list with the same data. Then, modify the data in the copy as necessary. To modify the data in more elaborate ways, use the transform feature described in Copying and Transforming a Rate List, instead of modifying the data manually. For example, you can use the transform feature to convert all the currencies in a rate list to a different currency. NOTE: Do not edit the Currency field when you copy and modify a rate list. To modify this field, use the Transform function described in Copying and Transforming a Rate List. To copy and modify a rate list
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
