Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference >
Check Eligibility & Compatibility - Default Workflow
This workflow is responsible for checking the eligibility and compatibility of a quote or order line item. This workflow is shown in Figure 19.
Figure 19. Check Eligibility & Compatibility - Default Workflow
Workflow Description. This workflow does the following:
- Project Asset Key?. Determines whether the Projected Asset Key is present.
- Query Projected Asset. If the Projected Asset Key is present, searches for the asset.
- Name Change. Calls the Conditional Action Transform for the Business Service Row Set Transformation Toolkit.
- Product E & C. Calls the Product Eligibility & Compatibility - Default workflow.
- Store Instance Information. Stores instance information that will be used in the Delete RowSet Data step.
- Multiple Popup Workflow. Calls the Compatibility Multiple Popup Workflow.
- Delete RowSet?. Determines whether any Line Items in the Row Set have been marked for deletion.
- Delete RowSet Data. Deletes any Line Items that are marked for deletion.
