Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating Configuration Rule Explanations
Use this procedure to translate configuration rule explanations for a customizable product. To translate a configuration rule explanation
- Navigate to the Administration - Product, then the Product Definitions view.
- In the Products list, select and lock the desired customizable product.
- In the Versions list, click the Work Space version.
- Click the Constraints view tab.
- In the Constraints List, select the constraint containing the explanation you want to translate.
- From the Constraints List menu, choose Translate Constraint Description.
A dialog box appears that displays the rule explanation translations you have already created.
- In the dialog box, add a new record and complete the necessary fields, described in the following table.
Language |
Displays the name of the language after you select the code. |
Code |
Select a language code. |
Description |
Enter the translation of the description. |
