Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating Relationship Names
You can translate relationship names for a product with components the following ways:
- You can translate the relationship name at the Product Classes level, so all products in the class inherit the translation.
- You can translate the relationship name at the Product level, so the translation applies only to that product.
To translate a relationship name at the Product Class level
- Navigate to the Administration - Product screen, then the Product Classes view.
- Select and lock the desired Product Class.
- In the Versions list, click the name of the Work Space version.
- In the Structure list, select the relationship whose name you want to translate.
- From the Structure list menu, choose Translate Relationship.
A dialog box appears that displays the relationship name translations you have already created.
- In the dialog box, add a new record and complete the necessary fields, described in the following table.
Language |
Select a language code. |
Relationship Name |
Enter the translation of the relationship name for that language. |
To translate a relationship name at the Product level
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select and lock the desired product with components.
- In the Versions list, click the Work Space version.
- Select the relationship whose name you want to translate.
Language |
Displays the name of the language after you select the code. |
Code |
Description |
Enter the translation of the description. |
