Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Process of Creating Dynamically Generated Smart Part Numbers >
Defining the Part Number Templates
Next, define the part number template. This task is a step in Process of Creating Dynamically Generated Smart Part Numbers. To define the part number template
- In the Name field of the Smart Part Number record, click the name you entered.
The name is a hyperlink. The Part Number Method view appears.
- In the Part Number Template list, add a new record and complete the necessary fields, described in the following table.
Pre-Fix |
Enter a static text that appears before all other parts of the smart part number generated by the application |
Attribute Name |
Select the attribute for this section |
Post Fix |
Enter a static text that appears after all other parts of the smart part number generated by the application |
Abbreviation Method |
Select an abbreviation method for the attribute mapping |
Sequence |
Enter a sequence. The sequence determines the order of the section in the part number. |
- Repeat Step 2 for each section you want to include in the part number.
