Siebel Public Sector Guide > Administering Benefits Cases > Process of Configuring Applications >
Setting Up Verification Templates
Administrators must set up the templates that agents use as a guideline to verify the information in submitted benefits applications. These templates determine the specific items in submitted applications that agents must verify. After agents use a template to verify information in submitted applications, an administrator can change that template. However, this changed template does not apply to the previous agent verifications. After an agent uses a verification template, an administrator cannot delete that template. (The trash can icon for the template and the template items become disabled.) This task is a step in Process of Configuring Applications. To set up a verification template
- Navigate to the Administration - Case screen, then the Verification Templates view.
- In the Verification Templates list, create a new record, and complete the fields as appropriate.
The following table describes some of the fields.
Template Name |
Type the name of the template. |
Case Type |
Select the type of benefits or immigration program applicable to the case. For cases that are automatically created from applications submitted on a self-service Web site, this field in the case has a value of Other, but agents can change this value. Additional values include Food Stamps, Medical Assistance, Cash-Financial Assistance, Child Care, Unemployment, Visa, Passport, and Citizenship. After an agent uses this template to verify information in submitted applications, you cannot change this field. (This field becomes read-only.) |
Description |
Type a description of the purpose of the template. |
Active |
Select this check box to indicate that agents can select this template when they verify applications. |
- In the Information Items list that appears below the Verification Templates list, add the application items that the agent must verify.
NOTE: If you do not add items to the template, then agents cannot select the template in the Template Name field of the Verification Plans view.
Order |
Type a number for this item. When an agent uses this template, this field indicates the order in which this item appears relative to the other items in the template. |
Name |
Type the name of the item that the agent must verify when using this template. |
Description |
Type a description of the item. |
