Siebel Public Sector Guide > Administering Siebel Public Sector > Process of Setting Up Approval Templates > Creating Approval Templates for LeadsPerform the following procedure to create an approval template for a lead. To allow users to select the appropriate templates from the Leads screen, you must select values for the following fields: Lead Type, Territory, Priority, Start Date, and Status when you create a lead approval template. If users need the template immediately, then make sure you set the Status field to Active and the Start Date field to the default creation time. The selection of templates that users see depends on the values in the lead record for Lead Type, Territory, and Lead Priority. For example, a user who creates a lead record with the values of Investigative (Lead Type), New York (Territory), and Immediate (Lead Priority), can select only an approval template with the same values. This task is a step in Process of Setting Up Approval Templates. To create an approval template for leads
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
