Siebel Public Sector Guide > Managing Investigative Cases > Process of Managing Lead Information > Submitting Leads for ApprovalWhen you select an approval template for a lead record, the Approvers view is populated with the list of approvers on the approval template. After this view is populated with the list of approvers, you can submit the lead for approval. Approvals are routed according to the sequence number for each approver. For more information, see Creating Approval Templates for Leads. After you submit a lead for approval, the lead is routed to the inbox of the first approver in the chain of approval. After that approver approves the lead, the lead is routed to the next approver in the chain, and so on. For more information, see Approving Cases in the Inbox. This task is a step in Process of Managing Lead Information.
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
