Siebel Public Sector Guide > Administering Siebel Public Sector >
Defining Locations
You can define locations. For more information about how organizations can use defined locations in Siebel Public Sector, see About Location Tracking. This task is a step in Roadmap for Administering Siebel Public Sector. To define a location
- Navigate to the Administration - Data screen, then the Location view.
- In the Location list, create a new record, and complete the fields as appropriate.
The following table describes some of the fields.
Location |
Type the name of the location. |
Type |
Select the type of location. Values include Hill, Mall, and National Park. |
Cross Street |
Type the location's cross street, if any. |
Country |
Select the country of the location. |
Altitude |
Type the altitude of the location. This field can be helpful when describing a location on a hill or other raised ground. |
Latitude |
Type the latitude of the location. |
Longitude |
Type the longitude of the location. |
UTM Easting |
Type the Universal Transverse Mercator Easting value of the location. |
UTM Northing |
Type the Universal Transverse Mercator Northing value of the location. |
- Scroll down to the Addresses list, and create a new record.
Street Address |
Type the street address for the location, if available. |
Street Address 2 |
Type the secondary street address for the location. |
Address Name |
Type a descriptive name for the address, for example, High Street Mall Address. |
Premise |
Select this check box if the address relates to a building or part of a building. |
Location |
Displays the value that you select in the Location field. |
- Repeat Step 3 until you add all the addresses that relate to the location.
Associating Existing Addresses with Locations
You can also associate existing addresses with a location. To associate existing addresses with a location
- Navigate to the Administration - Data screen, then the Addresses view.
- Select an existing address record or create a new record.
- In the Location field, select the location for the address.
