Siebel Public Sector Guide > Managing Investigative Cases > Process of Managing Lead Information >
Creating Lead Records
Perform the following procedure to create new lead records.
If automatic serialization is enabled for the Siebel Public Sector application, then you can update the serial number that is automatically generated for a lead record. You update the serial number when field values in the record change, and when those field values determine the serial number. Also, you update serial numbers when the serialization rule for the serial number changes after the serial number was last generated.
When you click Regenerate All in the Leads screen, the serial numbers for the selected lead record and any associated attachment records are regenerated. The serial numbers for associated sublead records remain unchanged. If you add a lead record on the Leads view of any screen (except for the Cases screen), then you must navigate to the Leads screen to regenerate the serial number.
NOTE:  The Case Name field is mandatory when you create a new lead record. Because you can associate leads with multiple cases, the lead serial number generated is based on the primary case record.
This task is a step in Process of Managing Lead Information.
To create a lead record
  1. Navigate to the Leads screen, then the Lead List view.
  2. Create a new record, and complete the fields as appropriate.
    The following table describes some of the fields.
    Field
    Description
    Lead ID
    Displays an automatically generated number that uniquely identifies the lead.
    Lead Name
    Type a descriptive name for the lead.
    Lead Priority
    Select the importance of the lead. Values include Routine, Deadline, Immediate, and Priority.
    Lead Type
    Select the type of lead. Values include Investigative, Administrative, and Site Visit.
    Lead Sub-Type
    Select a further clarification of the lead type. The values that you can select depend on the value that you select in the Lead Type field.
    Lead Serial #
    Displays the serial number for the lead. A serialization rule populates this field when you save the record.
    According to the default serialization rules, the serial number assigned to each lead is based on the primary case number associated with the lead. For example, if the case number is NY-2B-296-3964041, then the lead serial number might be NY-2B-296-3964041-296-3964055.
    Lead Status
    Displays a status of Active for the lead.
    Lead Sub-Status
    Select a further clarification of the lead status. The values that you can select depend on the value that you select in the Lead Status field.
    Assigned To
    Displays the ID of the user who creates the lead record. You can assign additional users to the lead. The user who creates the lead record remains the primary team member for the lead.
    Approval Template
    Select a template that determines the approval routing for the lead. The lead record is automatically routed to each approver's inbox until the record has all approvals in the chain. For more information, see Reviewing Approvers for Leads and Submitting Leads for Approval.
    Case Name
    Select a case that is associated with the lead. When you select a case name, the Case Number, Case Serial number (#), and Case Owner fields are populated. You can associate multiple cases with a lead.
Siebel Public Sector Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
