Table 56. Parameters of the Database Extract Server Component
CD directory |
CDDir |
Optional |
Name of a folder where Siebel Remote copies the snapshot files that the CD-ROM initialization uses. |
Client Database Transaction Log |
ClientDbTxnLog |
Optional |
Name of the transaction log that includes details about modifications to the remote database. For more information, see Using a Transaction Log to Optimize Performance. |
Client Name |
Client |
Required |
Name of the remote client for which Siebel Remote is extracting a database. This value corresponds to the Mobile Client Name field in the Mobile Clients view. For more information, see Specifying Client Names. |
Database Init Method |
InitMethod |
Optional |
Method for creating the Siebel Remote database. The default value is SQL Anywhere. |
Database template file name |
DbTmplFile |
Optional |
Name of the SAP SQL Anywhere Database Template file. The default value is sse_utf8.dbf. You must make sure this entry matches the value that you enter for the SQL Anywhere Database parameter in the Generate New Database server component. If you use the encrypted local database template, then enter the following value in these locations: sse_encr.dbf
Encrypt client Db password |
EncryptLocalDbPwd |
Optional |
If TRUE, then Siebel Remote uses RSA SHA-1 encryption to encrypt the local database password before it sends this password to the local database for authentication. The default value is FALSE. For more information, see Setting Encryption on the Local Database Password. |
Extract all Repository Tables |
ExtractRepos |
Optional |
Configures Siebel Remote to include repository tables in a database extract. Values are TRUE and FALSE. If the Extract all Repository Tables parameter is set to TRUE, then the Get is not necessary. Not using the Get can reduce the amount of time that you require to configure an environment for a developer. |
Last Extract Date |
ExtractSince |
Optional |
Specifies a date-time value for extraction. You must use the following format: YYYY-MM-DD HH:MM:SS
If specified, then the Database Extract server component extracts a remote client only if Siebel Remote has not extracted this client since the date-time value that you specify in the Last Extract Date parameter. |
Last Sync Date |
SyncSince |
Optional |
Specifies a date-time value for synchronization. You must use the following format: YYYY-MM-DD HH:MM:SS
If specified, then the Database Extract server component synchronization a remote client only if Siebel Remote has not extracted this client since the date-time value that you specify in the Last Extract Date parameter. |
Maximum data file size |
DatFileSize |
Optional |
Sets the maximum size of a data file in megabytes:
- The minimum size is 1.
- The maximum size is 1000.
- The default value is 500.
Message Language Code |
Language |
Optional |
Extract messages for this language. The default value is ENU. |
Mobile Client Version |
ClientVersion |
Optional |
Specifies the remote client software version. This parameter is important during an upgrade. The default value is 2000 for release Siebel CRM 7.x of the software. |
Move Siebel Remote Client |
Move |
Optional |
For more information, see Using the Move Siebel Remote Client Parameter. |
Nodes Per Group |
NodesPerGroup |
Optional |
if the Optimal Mode parameter is TRUE, then the Nodes Per Group parameter specifies the number of users who Siebel Remote extracts together as a group. The default value is 35. |
Optimal Mode |
OptMode |
Optional |
Specifies to use the optimal mode to extract a group of users. The default value is FALSE. |
Save Client Transactions |
SaveTxns |
Optional |
Save pending client transactions during database initialization. The default value is TRUE. This feature does not work during an upgrade. The Save Client Transactions parameter is valid only for the remote client. |
Truncate TS Table |
TruncateTSTable |
Specifies to truncate the S_DOCK_INITM_n table instead of deleting it after the Siebel database extract task completes. Used in the cleanup phase. The default value is FALSE. If you run the Database Extract server component with the Truncate TS Table parameter set to TRUE, then the user ID that you use to run the server component must possess administrator privileges on the Siebel Server. |
TS Block Size |
TSBlockSize |
Optional |
Block size for the dobjinst.dbf file in bytes. The default value is 0. Siebel Remote automatically calculates the block size depending on the total number of rows that are visible in the remote client. |
TS Cache Size |
TSCacheSize |
Optional |
Cache size for the dobjinst.dbf file in kilobytes. The default value is 2048 kilobytes. |
TS Table Number |
TSTableNum |
Number of database tables in the dobjinst.dbf file that are available for Database Extract. The range is 1 through 48. The default value is 1. This parameter is the end number of the S_DOCK_INITIM_n table, where n is the TS Table Number. |
