Siebel CTI Administration Guide > Administering Siebel Communications Server > Enabling Session Communications > Enabling Communications Sessions for Siebel Web ClientUsers can access communications using the Siebel Web Client by connecting the Web browser to an Applications Object Manager for which server component parameter values are set as described in this topic. For more information about setting server component parameter values, see Siebel System Administration Guide. To enable or disable session communications for Siebel Web Client users
After you set the CommEnable parameter value, the change takes effect for each subsequent user login. Optionally, you can ask existing users to log out and log in again. For more information about using Siebel Server Manager (GUI or command line), see Siebel System Administration Guide. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
