Siebel CTI Administration Guide > Administering Siebel Communications Server > Enabling Session Communications >
Parameters for Communications Session Manager
Parameters relating to log files can be specified as server component parameters for Communications Session Manager. These parameters are described in Table 48.
NOTE:  For the parameters listed in Table 48, if the parameter value is changed while the Communications Session Manager is running, then the changed value affects communications sessions for all users who log in subsequently.
Table 48. Communications Session Manager Parameters
Parameter Name
Display Name
Default Value
Description
LogDebug
Log Debug Message
False
Specifies whether the log file specified with the LogFile parameter must contain extra detail.
LogFile
Log File
SComm.log
Specifies the name of the log file to create for each agent's communications session.
For example, where the parameter is set to SComm.log, files named SComm_user.log are created, where user is each agent's Siebel login name.
These files are written in the log subdirectory of the Siebel Server installation directory.
MaxLogKB
Maximum Log Size (KB)
1024
Specifies the maximum size, in Kilobytes, of log files specified using LogFile.
ReleaseLogHandle
Release Log Handle
True
Indicates that the log file handle for each agent is released periodically, after logs have been generated.
The default setting of True provides better performance.
When ReleaseLogHandle is False, some log files might not be generated if the number of concurrent users exceeds the file-handle capacity provided by the operating system.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
