Siebel CTI Administration Guide > Configuring Advanced Communications Features > Integrating with the Customer DashboardThe customer dashboard contains fields with customer-related data for an agent to view. Although the customer dashboard typically displays contact information, you can configure it in Siebel Tools to display other fields. The customer dashboard appears in the Web browser in the Siebel application, such as Siebel Call Center, as follows:
For more information about configuring the customer dashboard using Siebel Tools, see Configuring Siebel Business Applications. You can configure customer dashboard fields to be populated, or cleared, automatically upon the execution of a communications event or command. For example, the fields might be populated from an event log when an inbound work item arrives, or cleared from an event log if the caller is not found in the database. The fields in the dashboard are populated with customer data when you invoke a business service and method and pass values from business component fields or event data fields, such as the ANI phone number of a caller. If a match is produced, then the dashboard fields can be populated. Related TopicRelated BooksExample Events for Updating and Clearing Customer DashboardFor example, the following sequence of event handler, event response, and event logs causes the dashboard to be populated with data, or cleared. In these examples, when a single matching contact record is found, the dashboard is populated. When no contact records are found, or multiple records are found, the dashboard is cleared. Adjust your event definitions as necessary, such as if you are using a different business component than Contact. [EventHandler:InboundCallReceived] [EventResponse:OnInboundCallReceived] If contact data is found, then the following event log updates the customer dashboard: [EventLog:LogIncomingCallContactFound] If no contact record is found, then the following event log clears the customer dashboard: [EventLog:LogIncomingCallContactNotFound] If multiple contact records are found, then the following event log clears the customer dashboard: [EventLog:LogIncomingCallMultiContactFound] |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
