Siebel CTI Administration Guide > Configuring Advanced Communications Features > Viewing Communications Status Data > Viewing Channel Status DataYou can use the All Channel Items view to view status data about current communications work items for agents. For each work item, the view displays the:
NOTE: For each work item, the value displayed in the Start Time field is accurate only to the extent that the time is synchronized between the various computers running instances of Communications Session Manager or Application Object Manager.
Modifying How Channel Status Data Is DisplayedChannel status data is logged for display in the All Channel Items view only if the UpdateChannelStatusTable configuration parameter is set to True. In communications configurations provided with Siebel Business Applications, this parameter is set to True. For more information, see Specifying Parameters for a Communications Configuration. NOTE: Records in the All Channel Items view reflect current activity only. If any records persist in this view for past work items, then you might have to delete such records manually in this view. Distributing Status Data to AgentsCall-center administrators might want to distribute call-center statistics from the switch or CTI middleware to call-center agents for display in the message broadcast area of the Siebel client. For example, it might be useful for an agent to know how long a call has been in an ACD queue before taking the call, how many calls are currently in an ACD queue, or the average talk time for a call. Consult the documentation for your switch or CTI middleware for information about how to retrieve call-center statistics. You configure message broadcasting in the Message Broadcasts view, located in the Administration - Communications screen. For more information, see Siebel Applications Administration Guide. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
