Siebel CTI Administration Guide > Configuring Siebel CTI > Specifying Agents > Configuring AgentsThis topic provides instructions for configuring an agent after the agent has been added to at least one communications configuration. Using the Agent General Profile view, you can add the agent to additional configurations, associate the agent with telesets, and specify the ACD queues from which the agent receives voice calls. You can also designate which configuration is primary for the agent and which ACD queues are primary for the agent. NOTE: The Agent General Profile view lists only those agents who have been associated with one or more configurations. For more information, see Creating or Modifying a Communications Configuration. Only one configuration can be designated as primary for the agent, and only one configuration is in effect at one time. When an agent logs in for the first time, the primary configuration is in effect for the agent. In the Communications options of the User Preferences screen, the agent can choose a different configuration, which is in effect the next time the agent logs in. For more information, see Setting Communications User Preferences. You can associate telesets with an agent in this procedure only if the telesets have been defined. For more information, see Specifying Telesets. You can define the Agent Login and Password that are retrieved from the database each time an agent logs in to the ACD queue. You must provide these values for agents who are configured to log in to the ACD queue, when required by the ACD. You do not have to specify these values for other users. You only have to specify the agent login and password once for an agent. NOTE: For an Aspect switch, Agent Login also represents the number that other call-center agents dial to reach the agent. For more information about configuring login commands, see Configuring Communications Login and Logout. For more information about agent login procedures, see Using the Communications Toolbar. This topic is part of Specifying Agents.
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
