Siebel CTI Administration Guide > Configuring Siebel CTI > Specifying TelesetsThis topic describes how to specify telesets. It contains the following information:
Use the All Telesets view to specify telesets for your communications configurations, including associating agents and extensions. Because teleset data is specific to your enterprise, you must specify this data for your call center. Some demo telesets are defined in the Sample Database, but no predefined teleset data is otherwise provided. Teleset data is indirectly associated with communications configurations, by way of the agents who use the teleset. In this way, Siebel Communications Server can support CTI functions for your call center agents. You define extensions for the telesets, then associate the extensions with agents (unless you use hoteling) that have already been associated with a configuration. For information about how end users can set preferences for telesets and extensions, see Setting Communications User Preferences. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
