Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications Events > Creating Event ResponsesThis topic describes how to create event responses, using the All Event Responses view. You can associate zero or more event logs with an event response. Some event responses do not need an event log. The Event Handlers view tab in the All Event Responses view lets you view the event handlers with which the current event response is associated. The Event Responses view tab in the All Event Logs view lets you view the event responses with which the current event log is associated. This topic is part of Defining Communications Events. NOTE: If you are implementing a custom communications driver, then see also Configuring Communications List of Values Types.
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
