Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications EventsThis topic describes how to define communication events. It contains the following information:
You can specify events for your communications configuration. Siebel Communications Server supports three event types: In general, you create event logs first, then create event responses and associate event logs with them, then create event handlers and associate event responses with them. You might add parameters for an event response after you create it, and you might also add them after you have associated the event response with a particular event handler. Different procedures are provided for these purposes. Some event definitions are provided with Siebel Business Applications. Verify whether the events in your communications configuration meet your needs before you modify them or create new events. For more information about the role of events within a communications configuration, see About Communications Configuration Data. For more information about working with communications events, including supported parameters, see Configuring Events and Commands. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
