Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications Events >
Creating Event Handlers
This topic describes how to create event handlers, using the All Event Handlers view. Associating an event response to an event handler is optional. The Event Handlers view tab in the All Event Responses view lets you view the event handlers with which the current event response is associated. The Associated Event Logs view tab in the All Event Handlers view lets you associate an event log with the event response that is associated with the current event handler. The procedure is the same as that described in Creating Event Responses. In Step 6 in the following procedure, associating a profile with an event handler is optional. It can help you avoid collisions if the same device event is available in multiple drivers. This topic is part of Defining Communications Events. NOTE: If you are implementing a custom communications driver, then see also Configuring Communications List of Values Types.
To create an event handler
- Navigate to the Administration - Communications screen, then the All Event Handlers view.
- In the Event Handlers list, add a new record.
- In the Name field, enter the name of the event handler.
- Specify the configuration to associate this event handler with:
- In the Configuration field, click the select button. The Pick Configuration dialog box appears.
- Scroll to display any additional records that are not shown, or use Query or Find to locate records matching certain criteria.
- Select an existing configuration with which to associate the event handler, then click OK.
- Specify the event response to associate this event handler with:
- In the Event Response field, click the select button. The Pick Event Response dialog box appears, displaying existing event responses associated with the same configuration as the event handler.
- Select an event response with which to associate the event handler, then click OK.
- Optionally, specify the profile to associate this event handler with:
- In the Profile field, click the select button. The Pick Profile dialog box appears, displaying existing profiles associated with the same configuration as the event handler.
- Select a profile with which to associate the event handler, then click OK.
The name of the communications driver for the profile is displayed along with that of the profile.
NOTE: If you change or remove a profile associated with a configuration, then you must update the values in the Profile field for the configuration's event handlers.
- In the Device Event field, enter the name of the device event this event handler matches.
The device events that you can specify are those supported by the communications driver for the associated profile, or special events. For information about the events supported by the Virtual CTI driver, see Virtual CTI Driver Events.
- In the Order field, specify an integer representing the order in which this event handler is checked, relative to other event handlers specifying the same device event.
- Enter any optional comments for the event handler.
