Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications Commands > Creating Command Data DefinitionsThis topic describes how to create command data definitions, using the All Command Data view. The Commands view tab in the All Command Data view lets you view the commands with which the current command data definition is associated. This topic is part of Defining Communications Commands. NOTE: If you are implementing a custom communications driver, then see also Configuring Communications List of Values Types. To create a command data definition
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
