Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications CommandsThis topic describes how to define communication commands. It contains the following information:
You can specify commands for your communications configuration. Siebel Communications Server supports two command types: In general, you create command data definitions first, then create commands and associate command data definitions with them. In some contexts, the term command data refers to a command data definition. You might add parameters for a command data definition after you create it, and you might also add them after you have associated the command data definition with a particular command. Different procedures are provided for these purposes. Associating a command data definition to a command is optional. For example, group commands, which contain subcommands, do not need a command data definition. (A group command is a command that includes subcommands.) Some commands and command data definitions are provided with Siebel Business Applications. Verify whether the commands in your communications configuration meet your needs before you modify them or create new commands. For more information, see the following:
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
