Siebel CTI Administration Guide > Configuring Siebel CTI > Defining Communications Commands > Specifying Subcommands for a Group CommandThis topic describes how to specify subcommands for a group command. (A group command is a command that includes subcommands.) For more information about group commands that specify subcommands, see Communications Group Commands in the Communications Toolbar. This topic is part of Defining Communications Commands. NOTE: When you specify subcommands for a group command, do not specify invalid recursive relationships between subcommands and group commands. For example, do not specify a subcommand that is itself a group command for which the current group command is specified as a subcommand. A relationship like this invalidates the communications configuration when it is loaded for an agent's session and disables the communications toolbar. To specify subcommands for a group command
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
