Siebel CTI Administration Guide > Configuring User Interface Elements > Communications Toolbar Buttons and Commands > Communications Group Commands in the Communications ToolbarIn the communications configurations provided with Siebel Business Applications, commands whose names end in Group are commands that can contain several subcommands. Most of the communications toolbar buttons invoke group commands. A group command can invoke another group command. When a group command is executed, such as might occur when the user clicks the associated toolbar button, one of its subcommands is typically invoked, based on the current context. Alternatively, you can configure a group command to execute all subcommands, where this is appropriate. The order that you specify for each subcommand determines the sequence in which the subcommands are checked to find one that matches the context. For more information about group commands and subcommands, see Hierarchical Commands (Commands and Subcommands). |
Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
