Siebel CTI Administration Guide > Configuring User Interface Elements > Communications Toolbar Buttons and Commands > ToolTip Text for the Communications ToolbarThe ToolTips displayed when the agent points to a communications toolbar button are usually derived from the command in the communications configuration. They might also be obtained from the communications driver, or from the associated command object definition in Siebel Tools. The ToolTip text is derived in this fashion:
Communications drivers and configurations provided with Siebel Business Applications provide ToolTip text. If you use such a driver, then ToolTip text derived from Siebel Tools is not used. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
