Siebel CTI Administration Guide > Configuring User Interface Elements > About Communications Panel and Communications Toolbar Configuration > Communications Toolbar Commands and BitmapsTable 21 displays the names of the bitmap object definitions that are associated with the Siebel Tools commands for the communications toolbar items. From left to right, the table displays the same Siebel Tools command names shown in Table 20, the name of the bitmap object definition specified for HTML Bitmap, and the name of the bitmap object specified for HTML Disabled Bitmap. HTML Bitmap is for controls in an enabled state, while HTML Disabled Bitmap is for controls in a disabled state. The applicable image file names can be found in Siebel Tools, by viewing the bitmap object definitions for the bitmap category HTML Command Icons. The source image files are installed in the following locations:
where language_code represents the language code for the installed software, such as ENU for U.S. English. NOTE: New or updated files on the Siebel Server are automatically populated to the Web server whenever the Web server (where the Siebel Web Server Extension is installed) is restarted. Files can also be manually updated from the Siebel Server without restarting the Web server. For more information, see Siebel Security Guide and the Siebel Installation Guide for the operating system you are using. As noted, Table 21 displays the names of the bitmap object definitions that are associated with the Siebel Tools commands for the communications toolbar items. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
