Siebel CTI Administration Guide > Developing a Communications Driver > Testing Communications DriversThe Communications Driver Test Engine (Test Engine) is a standalone tool that simulates parts of a Siebel environment for you to test the reliability and capacity of the communications driver that you develop. The Test Engine does not test the Communications Server or your communications configuration elements. You can use the Test Engine to test your communications driver when connected to your CTI middleware by specifying appropriate driver parameters in the definition file (DEF) that you develop for testing your communications driver. Before using the Test Engine, you configure settings for your communications driver. The Test Engine writes the results of the test to log files. You can specify the log file names by configuring the DEF file. For additional information about communications drivers, see Configuring Communications Drivers and Profiles. Table 59 describes the format that your DEF file must adhere to in order to simulate multiple calls. The following procedure describes how you run the Test Engine tool to test a communications driver. To test a communications driver
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
