Siebel CTI Administration Guide > Configuring Events and Commands > About Events and Commands > Event and Command ParametersThis topic provides general information about parameters that you can define for your event and command definitions. Field Types for Event and Command ParametersParameters for each type of event or command use one of the following field types:
Forms of Event and Command ParametersParameters of character type can be one of the following forms:
Table 6 illustrates the usage of parameters of the three forms of character fields. Parameters must be specified in a form similar to what is shown in this table. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
