Siebel CTI Administration Guide > Communications Operations for End Users > Using the Communications Toolbar > Changing the Ready StateYou can specify that you are unavailable to receive new inbound work items of each supported channel type (such as when you need time to complete after-call work, or you are taking a break). For each channel type, new work items are not assigned to you while the Not Ready state is set for that channel. You can choose Change Ready State separately for each channel type, or for work items of all supported channel types. The toolbar button is a toggle. If all channels are in Not Ready state, then the button is toggled down (appearing to be depressed). If any, or all, channels are in Ready state, then the button is toggled up. Indicating That You Are Not Ready to Receive Inbound Work ItemsThis procedure describes how to indicate that you are not ready to receive inbound work items. To indicate that you are not ready to receive inbound work items
NOTE: If you click the Change Ready State button to set the Not Ready State for all channel types, but the button does not display as toggled-down (depressed), then this might be due to a configuration error or some other issue for one or more channels. Report this issue to your supervisor. You can still choose the Not Ready State for individual channels, as described in the second bullet item. Indicating That You Are Ready to Receive Inbound Work ItemsThis procedure describes how to indicate that you are ready to receive inbound work items. To indicate that you are ready to receive inbound work items
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
