Siebel CTI Administration Guide > Communications Operations for End Users > Using the Communications Toolbar >
Forwarding Work Items
You can have inbound work items of supported channel types forwarded to you, such as having voice calls forwarded to you at a different extension. Only work items subsequently routed to you are forwarded. The toolbar button is a toggle, where the button name changes depending on the state.
To specify forwarding for inbound work items
  1. In the text input field, enter the contact information, such as a phone extension, where you want your work items forwarded.
  2. Click Forward Work Items.
  3. Toggle the button to cancel forwarding.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
