Siebel CTI Administration Guide > Views for Communications Administration >
Views for Defining Events
The following views are used to specify event handlers, event responses, and event logs:
  • All Event Logs. Create or modify each event log, specify parameters and values, and associate the event log with a configuration.
  • All Event Responses. Create or modify each event response, specify parameters and values, and associate the event response with a configuration. Also associate the event response with one or more event logs.
  • All Event Handlers. Create or modify each event handler, specify parameters and parameter values, and associate the event handler with a configuration, and optionally with a profile. Also associate the event handler with an event response.
For more information, see Defining Communications Events.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
