Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Process of Configuring Load Balancing for Siebel Business Applications > Setting the Load Balancer Connection Timeout IntervalMany third-party HTTP load balancers allow you to set a connection timeout interval. When the timeout occurs, the load balancer's SISNAPI connection to the Application Object Manager on the Siebel Server is terminated. In addition, Application Object Managers have a configurable timeout parameter, SISNAPI Connection Maximum Idle Time (alias ConnIdleTime). When a session is idle for the specified time, the Application Object Manager closes the session. This task is a step in Process of Configuring Load Balancing for Siebel Business Applications. To set the load balancer connection timeout interval
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
