Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Process of Configuring Load Balancing for Siebel Business Applications > Monitoring Servers with Siebel Native Load Balancer or Third-Party HTTP Load BalancersThe Siebel native load balancer and most third-party HTTP load balancers support server health monitoring. To set up server health monitoring, you configure the load balancer to send an HTTP GET request to the server URL. This task confirms that the Siebel Server is running on the specified server computer and that SCBroker is listening at the specified port. This health check does not verify that specific Application Object Managers or other server components are running on the computer. CAUTION: Do not use TCP Health Check. It might connect to SCBroker and remain connected until the SCBroker component parameter ConnRequestTimeout expires. During this period, SCBroker cannot handle new user-session requests. This task is a step in Process of Configuring Load Balancing for Siebel Business Applications. To set up monitoring for a Siebel Server
Guidelines for Setting Up Server MonitoringUse the following guidelines when you set up server monitoring:
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
