Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Preparing to Run Siebel Server Components > Enabling and Disabling Language-Specific Application Object Managers and Adding LanguagesWhen you installed and configured Siebel Business Applications software, you would have included one or more languages, as described in Installing and Deploying Siebel Business Applications with Multiple Languages. That topic also describes optional approaches to installing and deploying languages in a phased approach. If you install the Siebel Server with multiple languages and specify these languages as deployed languages when you configure the Siebel Server, then language-specific Application Object Manager components are created for each deployed language. If you decide that you do not require Application Object Managers for one or more of these deployed languages, then you can use Server Manager to disable such components prior to deployment. If you install multiple languages, then it is recommended that you deploy all of the installed languages when you run the Siebel Server Configuration Wizard. As stated, you can disable any language-specific components that you do not require. You must coordinate the language deployment tasks between your installations of Siebel Server and Siebel Web Server Extension. For more information about performing tasks in the Siebel Server Configuration Wizard, see Options for Configuring the Siebel Gateway Name Server, the Siebel Enterprise, and the SWSE Logical Profile. This topic is part of Preparing to Run Siebel Server Components. Related TopicsRelated Books |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
