Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Installing and Deploying Siebel Business Applications with Multiple LanguagesMultiple Siebel language packs can be installed and deployed as part of Siebel Business Applications installation and configuration, for the current release. Review this topic and related topics when planning multilingual deployments. Language installation is part of the installation procedure for each installable Siebel module. The task of adding and deploying new languages is described for Siebel Server, Siebel Web Server Extension (SWSE), Siebel Web Client, and Siebel Tools. Scenarios for deploying Siebel Business Applications with more than one language pack are described in Scenarios for Installing and Deploying Multiple Languages. See also General Requirements for Installing and Configuring Siebel Enterprise Server Components and other relevant topics. For a list of the languages supported by Siebel Business Applications, see 1513102.1 (Article ID) on My Oracle Support. See also Siebel Global Deployment Guide, Siebel System Administration Guide, and other applicable documentation. Note the following recommendations:
You can add languages to an existing installation of the same version of Siebel Enterprise Server, SWSE, Siebel Web Client, or Siebel Tools by using unattended mode (silent mode) only. After adding languages in this case, you must run the Configuration Wizards for the Siebel Server and the SWSE and perform the tasks to add new languages. See the limitations described for adding languages. If you include multiple languages with a Siebel Enterprise Server installation, then you designate one language as the primary language to be used for server messages and logging. Typically, the same primary language is also used for the Siebel database, which cannot be changed after database installation. If you install and deploy a new language in an existing installation, then you must add the language to the Siebel database and perform additional tasks using the Database Configuration Wizard, as described in About Language Deployment Tasks Using the Database Configuration Wizard. This topic contains the following information:
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
