Siebel Installation Guide for UNIX > Cloning a Siebel Installation >
Properties File Settings for Cloning an Installation
Table 24 describes the possible settings in the properties files for different cloning operations and provides some usage information. The properties files themselves also provide basic usage information. Different settings apply depending on the particulars of your cloning operation, such as whether you are creating or deploying a clone, cloning the Siebel Server or the Siebel Web Server Extension, using Microsoft Windows or UNIX, creating or deploying a full clone or a delta clone, and so on.
Table 24. Settings in the Siebel Cloning Utility Properties File
Setting
Cloning Operation
Description
Product
Creating a clone
Deploying a clone
The possible values are:
  • ses. Creates or deploys a clone of the Siebel Enterprise Server.
  • swse. Creates or deploys a clone of the Siebel Web Server Extension.
This setting cannot be null. It is predefined in the properties files provided with the Siebel cloning utility.
The properties files for cloning the Siebel Enterprise Server include ses in the file name. The properties files for cloning the SWSE include swse in the file name.
Mode
Creating a clone (which uses the value clone)
Deploying a clone (which uses the value deploy)
  • clone. Creates a clone (that is, a snapshot file) on a source computer.
  • deploy. Deploys a clone on a target computer, using a previously created snapshot file.
The properties files for creating a clone include source in the file name. The properties files for deploying a clone include target in the file name.
Type
Creating a clone
Deploying a clone
  • full. Creates or deploys a full clone, using a complete snapshot file.
  • delta. Creates or deploys a partial (delta) clone, using a delta snapshot file.
This setting cannot be null. It is predefined as full in the properties files provided with the Siebel cloning utility.
Source Location
Creating a clone
The location of the source instance for which you are creating a clone. This setting cannot be null.
Target Location
Deploying a clone
The location of the target instance where you are deploying a clone. This setting cannot be null. The value must be the same as the location of the source instance.
Snapshot Location
Creating a clone
Deploying a clone
The location of the snapshot file that you are creating or deploying. This setting cannot be null.
Zip FileName
Creating a clone
Deploying a clone
The name of the snapshot file, including the file extension, that will be created in the snapshot location or that will be deployed from the snapshot location. This setting cannot be null.
For Siebel Enterprise Server, an example file name is sessnapshot.zip. For SWSE, an example file name is swsesnapshot.zip.
Delta Zip FileName
Creating a clone (creating a delta clone only)
Deploying a clone (deploying a delta clone only)
The name of the delta snapshot file, including the file extension, that will be created in the snapshot location or that will be deployed from the snapshot location. This setting cannot be null for an operation to create or deploy a delta clone (that is, an operation of type delta).
Exclude File List
Creating a clone
A comma-separated list of files in the source instance that will be excluded when you create a clone. You can use wildcards. For each file that you specify, you must include the full path.
Source Host Name
Creating a clone (for Siebel Enterprise Server only)
The host name of the source computer for which you are creating a clone. This setting cannot be null.
Target Host Name
Deploying a clone
The host name of the target computer on which you are deploying a clone. This setting cannot be null.
Target Gateway Server Host Name
Deploying a clone (for Siebel Enterprise Server only)
The host name of the computer hosting the Siebel Gateway Name Server for the target instance.
Gateway Port
The port number of the Siebel Gateway Name Server for the source instance or target instance.
Language
The language code (such as RUS for Russian) for the primary language for the source instance or target instance. You must use the same setting for creating and for deploying a clone. This setting cannot be null.
UserName
The name of the Siebel Administrator user who will access the source instance or target instance, such as SADMIN. This setting cannot be null.
Password
The password for the Siebel Administrator user. This setting cannot be null.
Source Enterprise Name
The name of the Siebel Enterprise for the source instance.
Specify the Siebel Enterprise name if you are exporting the Siebel Enterprise configuration when you create the clone. Do this if deploying the clone will also create a new Siebel Gateway Name Server on the target computer. To export the Siebel Enterprise configuration, you also must specify Export Enterprise = Y.
If no value is provided, then no Siebel Enterprise configuration is exported when you create the clone.
Source Siebel Server Name
The name of the Siebel Server for the source instance.
Specify the Siebel Server name if you are exporting the Siebel Server configuration when you create the clone. This is the expected usage case for cloning a Siebel Server. To export the Siebel Server configuration, you must specify Export Siebel Server = Y.
If no value is provided, then no Siebel Server configuration is exported when you create the clone.
Export Enterprise
  • Y. Exports the Siebel Enterprise configuration when you create a clone. This setting assumes that the Siebel Enterprise has been defined for the source instance and is specified using Source Enterprise Name. The Siebel Gateway Name Server must be running when you create the clone.
  • N. Does not export the Siebel Enterprise configuration when you create a clone.
  • Y. Exports the Siebel Server configuration when you create a clone. This setting assumes that the Siebel Server is running on the source instance and is specified using Source Siebel Server Name. The Siebel Gateway Name Server must be running when you create the clone.
  • N. Does not export the Siebel Server configuration when you create a clone.
Target Enterprise Name
The name of the Siebel Enterprise for the target instance. This setting cannot be null.
If you exported the Siebel Enterprise configuration when you created the clone, then set Target Enterprise Name to match the setting you used for Source Enterprise Name. In this case, you are creating a new Siebel Gateway Name Server on the target computer. To import the Siebel Enterprise configuration, you must specify Import Enterprise = Y and set Create Gateway = Y.
If an existing Siebel Gateway Name Server runs on a computer that is different from the target computer, then specify the name of an existing Siebel Enterprise and point to an existing Siebel Gateway Name Server, which must be running. In this case, you are not creating the Siebel Gateway Name Server on the target computer. You must set Import Enterprise = N and Create Gateway = N.
Target Siebel Server Name
The name of the Siebel Server for the target instance. This setting cannot be null.
To import the Siebel Server configuration, you also specify Import Siebel Server = Y.
Import Enterprise
  • Y. Imports the Siebel Enterprise configuration when you deploy a clone. This setting assumes that the Siebel Enterprise configuration was exported when you created the clone. The Siebel Gateway Name Server must be running when you deploy the clone.
  • N. Does not import the Siebel Enterprise configuration when you deploy a clone.
  • Y. Imports the Siebel Server configuration when you deploy a clone. This setting assumes that the Siebel Server configuration was exported when you created the clone. The Siebel Gateway Name Server must be running when you deploy the clone.
  • N. Does not import the Siebel Server configuration when you deploy a clone.
Create Gateway
  • Y. Creates the Siebel Gateway Name Server when you deploy a clone. The Siebel Gateway Name Server is created using the settings for Target Host Name, Gateway Port, Username, and Password.
  • N. Does not create the Siebel Gateway Name Server when you deploy a clone.
Gateway.VersionString
Specifies the version string for the Siebel Gateway Name Server. Use this setting if you are creating a new instance of Siebel Gateway Name Server on the target computer.
Gateway.UseDefault
Use this setting if you are creating a new instance of the Siebel Gateway Name Server on the target computer.
Gateway.CreateDefault
Update SWSE
Deploying a clone (for SWSE only)
Updates the Siebel Web Server Extension configuration files (eapps.cfg and eapps_sia.cfg) to include the target host name. This setting must be Y.
Related Topics
Requirements When Cloning an Installation
Limitations When Cloning an Installation
Properties Files Used in Cloning Operations
Siebel Installation Guide for UNIX Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
