Table 13. Configuration Wizards for Siebel Business Applications Components
Associated Siebel Configuration Wizard |
Siebel Enterprise Server: Siebel Gateway Name Server |
The Siebel Enterprise Configuration Wizard (or Siebel Configuration Wizard) is the wizard associated with this component. Use this wizard to configure the Siebel Gateway Name Server, the Siebel Enterprise, and the SWSE logical profile. Run the Siebel Enterprise Configuration Wizard on the Siebel Gateway Name Server computer. (You installed this component using the Siebel Enterprise Server installer.)
Siebel Enterprise Server: Database Configuration Utilities |
The Siebel Database Configuration Wizard is the Configuration Wizard associated with this component. Use this wizard to install the Siebel database. Also use it to perform other tasks to set up the database to support your installed Siebel Business Applications and languages. Run the Siebel Database Configuration Wizard on the Siebel Server computer. (You installed Siebel Database Configuration Utilities using the Siebel Enterprise Server installer.)
Siebel Enterprise Server: Siebel Server |
The Siebel Server Configuration Wizard is the wizard associated with this component. Use this wizard to configure the Siebel Server. Run the Siebel Server Configuration Wizard on the Siebel Server computer. (You installed this component using the Siebel Enterprise Server installer.)
Siebel Web Server Extension (SWSE) |
The Siebel Web Server Extension Configuration Wizard (or SWSE Configuration Wizard) is the Configuration Wizard associated with this component. Use this wizard to configure the physical SWSE. Before configuring the SWSE, you must have created an SWSE logical profile using the Siebel Enterprise Configuration Wizard. Run this wizard on the Siebel Gateway Name Server computer. (You installed this component using the Siebel Enterprise Server installer.) Then run the SWSE Configuration Wizard on the Web server computer. (You installed the SWSE using the SWSE installer.)
