Siebel Installation Guide for UNIX > Installing Siebel Enterprise Server Components and the Siebel Web Server Extension > Installing Siebel Enterprise ServerThis topic provides instructions for installing the Siebel Enterprise Server components, using the GUI installation method, as part of standard Siebel Business Applications deployment. The Siebel Enterprise Server installer verifies that you have the required software at the necessary version levels for installing Siebel Business Applications software. NOTE: This topic includes instructions for installing Siebel Enterprise Server as a new installation or as a migration installation. For an existing installation, you perform a migration installation instead of a new installation. If you are installing from a remote computer, or using X-connectivity software to access a UNIX computer from a Windows computer, then see also Installing Siebel Business Applications from a Remote Server Computer. This topic contains the following information:
Related TopicsRelated Books |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
