Siebel Installation Guide for UNIX > Overview of Installing Siebel Business Applications > Roadmap for Installing Siebel Business Applications in a Migration Installation Case (Existing Installation)Use this roadmap to guide you in performing the installation tasks for deploying the current release of Siebel CRM, where there is an existing installation of a prior version. This is the migration installation case. Migration installation is a type of patch installation. The current release is Siebel CRM version 15.0 (Siebel Innovation Pack 2015). Use this roadmap when you have an existing Siebel Business Applications installation of a prior release of Siebel CRM version 8.1.1 or later, or version 8.2.2 or later. You must perform the migration installation tasks for your existing installed Siebel CRM software. TIP: For the upgrade case, where you are upgrading to the current release from a Siebel CRM release prior to version 8.1.1 or version 8.2.2, see Roadmap for Installing and Configuring Siebel Business Applications in an Upgrade Case (Existing Database) instead. In an upgrade case, you perform a full database upgrade instead of running Incremental Repository Merge. In general, this book uses the term migration to refer to a migration installation and uses the term upgrade to refer to a full database upgrade. NOTE: It is recommended that, for each applicable Siebel module, you install the latest Siebel Patchset release after you install the current release. Siebel Innovation Pack 2015, Patchset 5 or later includes some optional features that involve changes to the Siebel Repository. For an existing installation of Siebel Innovation Pack 2015, if you want to use these features, you must run Incremental Repository Merge after installing the patchset release. For more information, see About Siebel CRM Releases. This roadmap does not include the following required tasks that you must perform after performing the migration installation tasks:
The installation process for Siebel Business Applications in a migration installation case requires multiple tasks that you perform in the following general sequence:
Related Topics |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
