Siebel Installation Guide for UNIX > Requirements for Installing and Configuring Siebel Business Applications > About Installing Siebel Business Applications > About Siebel CRM ReleasesThis topic is part of About Installing Siebel Business Applications. Siebel CRM software releases and their various installation methods have evolved significantly. New types of releases are provide, and some of the traditional types of releases no longer apply. The current release is Siebel CRM version 15.0 (Siebel Innovation Pack 2015). This book describes the tasks and requirements that apply for the current release. An innovation pack release is similar to a traditional Siebel Fix Pack release (applicable to some prior releases), but includes new application functionality. In a limited sense, an innovation pack release could be considered a patch release, because, although you can install the release as a new installation, you can also install it for an existing installation, in the migration installation case. Siebel Fix Pack releases are no longer provided. This guide, the Siebel Installation Guide for the operating system you are using, is for installing the current release. The Siebel Installation Guides describe how to perform both new installations and migration installations. You install Siebel Enterprise Server, Siebel Web Server Extension, Siebel Web Client, or Siebel Tools as a new installation of the current version of the software or as a migration installation. For more information, see Installation-Related Changes for Siebel Innovation Pack 2015 and similar topics for prior releases. NOTE: For an existing installation, running Incremental Repository Merge is required after performing a migration installation for Siebel Innovation Pack 2015. For more information, see About Database Updates for the Current Release. Table 25 lists the major Siebel CRM installable modules for Siebel CRM version 15.0 and shows which installation methods are supported in order to install the current release as a new installation or as a migration installation for an existing installation, where applicable. Both new installations and migration installations use the same installers and are one-step installations.
For information about the features and fixes provided in Siebel Business Applications for prior Siebel Innovation Pack and Siebel Fix Pack releases, and about the configuration requirements for those features, see the applicable Siebel Maintenance Release Guide on My Oracle Support. For versions of Siebel Maintenance Release Guide for prior releases, see 880452.1 (Article ID) on My Oracle Support for version 8.1.1.x or see 1441523.1 (Article ID) for version 8.2.2.x. Many of the configuration steps documented for prior Siebel Fix Pack releases are superseded by the Incremental Repository Merge feature. For information about using Incremental Repository Merge, see Siebel Database Upgrade Guide. Typically, no additional Siebel Configuration Wizard tasks are associated with a migration installation. You would not run the Siebel Configuration Wizard to configure a module that was already configured. However, requirements might vary for a given release, or for using particular functionality. In some cases, you might have to perform a new installation instead of a migration installation or you might need to reconfigure a server after doing a migration installation. Siebel Patchset releases are provided for the current release, each of which provides several fixes. The fixes are provided on a cumulative basis in each Siebel Patchset release. In some cases, installing a particular Siebel Patchset release might be required or strongly recommended. In general, this guide does not provide details about installing or uninstalling Siebel Patchset releases. Exceptions are the topics about installing Oracle Database XE with Siebel Tools or Siebel Mobile Web Client, when you install Siebel Innovation Pack 2015, Patchset 5 or later. For more information, see Installation-Related Changes for Siebel Innovation Pack 2015. The information in this guide complements the existing documentation for installing the applicable Siebel Patchset release. For more information, see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. Siebel Innovation Pack 2015, Patchset 5 or later also includes some optional features that involve changes to the Siebel Repository. These features are already included if you install a new Siebel database or perform a full database upgrade after installing Siebel Innovation Pack 2015, Patchset 5 or later. For an existing installation of Siebel Innovation Pack 2015, if you want to use these features, you must run Incremental Repository Merge after installing the patchset release. (If you have already run Incremental Repository Merge for Patchset 5 or later, then you do not need to run it again for subsequent patchset releases.) For more information about Incremental Repository Merge, see Siebel Database Upgrade Guide. NOTE: You must verify the availability, characteristics, and requirements of any future releases, including any Siebel CRM version 15.x releases, that might also be covered by this guide (or updated versions of it) or by other documentation. The installation tasks and requirements for all future releases are subject to change. Related Books |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
