Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing the Siebel Web Client >
Installing the Siebel Web Client as a Migration Installation
Use the following procedure to install the Siebel Web Client as a migration installation for the current release, Siebel CRM version 15.0. Migration installation is a type of patch installation. The information applies to both the Siebel Mobile Web Client and the Siebel Developer Web Client. NOTE: Use this procedure only when an earlier version of the Siebel Web Client is already installed (Siebel CRM version 8.1.1.x or version 8.2.2.x). Otherwise, you must follow the steps in Installing the Siebel Web Client as a New Installation instead.
During a migration installation, the original Siebel Web Client installation directory is renamed from OriginalName to OriginalName_pre15.0. For example, if the original installation directory name (OriginalName) was Client_1, then this directory is renamed to Client_1_pre15.0. The new Siebel Web Client installation directory is named OriginalName, such as Client_1. Retain the original installation directory, in case you choose to perform a rollback uninstallation later. For more information, see Rolling Back the Siebel Web Client. This topic is part of Installing the Siebel Web Client. This task is a step in Roadmap for Installing Siebel Business Applications in a Migration Installation Case (Existing Installation). To install the Siebel Web Client as a migration installation
- Review About Installing the Siebel Web Client or Siebel Tools.
- Exit any Siebel software on the client computer where you are installing the current release.
NOTE: For a Siebel Mobile Web Client using the Siebel QuickStart feature, you must also exit the QuickStart agent if it is running. To do this, right-click the QuickStart icon in the system tray, and then choose Exit. For more information, see About Siebel QuickStart.
- In Windows Explorer, navigate to the Siebel image location for the current release, and then to the directory where the installer is located. Navigate to
Siebel_Image\Windows\Client\Siebel_Web_Client\Disk1\install.
In this path, Siebel_Image is the directory for your version-specific Siebel installation image, such as C:\Siebel_Install_Image\15.0.0.0.
- To start the Siebel Web Client installer, double-click setup.bat.
The Siebel Web Client installer displays the Welcome screen.
- Click Next.
A screen appears that prompts for email contact information.
- When prompted for the email address and password corresponding to your My Oracle Support account, click Next. (This information is not used in this context.)
The Select Installation Task screen appears.
- To perform a migration installation of the Siebel Web Client software where an existing prior installation of version 8.1.1.x or version 8.2.2.x is present, choose Migration Installation, and click Next.
The Installation Migration Details screen appears.
- Confirm or select the name and location of your existing installation, and then click Next. Do the following:
- Confirm the existing installation name, or select it from the drop-down list.
- Confirm the existing installation location, or select it from the drop-down list.
For more information about Oracle home and installation path requirements, see File and Directory Naming Conventions.
The Summary screen appears. This screen displays the location where the Siebel Web Client will be installed.
- Review the information in the Summary screen. Before you proceed, confirm that you have met all of the installation requirements, such as for disk space. Then do one of the following:
- When the browser is displayed and indicates that ActiveX controls have been deployed, close the browser window.
NOTE: The ActiveX controls are used only for applications deployed using high interactivity.
- When the Next button becomes available, the installation is complete. Click Next.
The Finish Installation screen appears. This screen indicates whether the installation was successful and shows the location of the installer log file. You can access this file to review the installation results. This screen also shows the new location of the original installation, which the installer moved before it performed the new installation.
- Review the report that is generated about any conflicts between your customized files and the files that are delivered by the Siebel Web Client installer. As needed, copy any of your customized files from the original installation to the new migrated installation.
Conflicts are identified in the file overwrittenfiles_timestamp.log, which is created in the SIEBEL_CLIENT_ROOT\cfgtoollogs\oui directory (in the new Siebel Web Client installation).
- To close the installer, click Close.
The Siebel Web Client installation is now finished. Siebel application shortcuts are created in the program folder that you specified in Step 8. For more information about these shortcuts, see Siebel Web Client Shortcuts.
- After installing the Siebel Web Client software:
- Repeat this procedure on each computer with a Siebel Web Client installation to be migrated.
