Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing the Siebel Web Client >
Installing the Siebel Web Client as a New Installation
Use the following procedure to install the Siebel Web Client as a new installation for the current release, Siebel CRM version 15.0. Some of the information applies to only the Siebel Mobile Web Client or only the Siebel Developer Web Client. NOTE: Use this procedure only when Siebel Web Client is not already installed. Where an earlier version of Siebel Web Client is already installed, you perform a migration installation instead, as described in Installing the Siebel Web Client as a Migration Installation.
This topic is part of Installing the Siebel Web Client. This task is a step in:
To install the Siebel Web Client as a new installation
- Review About Installing the Siebel Web Client or Siebel Tools.
- In Windows Explorer, navigate to the Siebel image location for the current release. Then navigate to the directory where the installer is located. Navigate to
Siebel_Image\Windows\Client\Siebel_Web_Client\Disk1\install.
In this path, Siebel_Image is the directory for your version-specific Siebel network image, such as C:\Siebel_Install_Image\15.0.0.0.
- To start the Siebel Web Client installer, double-click setup.bat.
The Siebel Web Client installer displays the Welcome screen.
- Click Next.
A screen appears that prompts for email contact information.
- When prompted for the email address and password corresponding to your My Oracle Support account, click Next. (This information is not used in this context.)
The Select Installation Task screen appears. The New Installation task is selected by default.
- To perform a new installation of Siebel Web Client software where no existing installation of Siebel CRM version 8.1.1.x or version 8.2.2.x is present, click Next.
The New Installation Details screen appears.
- Enter a name for your installation and specify the installation location, and then click Next. (Note the installation name and location for future reference.) Note the following:
- The default installation name (Oracle Home Name) is CLIENT_HOME. The value that you specify is used in the parent program folder name for the Siebel application client shortcuts. (A separate program folder is created for the Oracle Universal Installer software.) If you have an existing installation, then you must specify a new name for the new installation.
- The default installation path (Oracle Home Location) for a new installation is
C:\siebel\15.0.0.0.0\Client or a similar value. Accept the default path or specify a different location by typing it directly or by clicking Browse. If you have an existing installation, then you must specify a new path for the new installation.
For more information about Oracle home and installation path requirements, see File and Directory Naming Conventions.
The Select Languages screen appears. All of the languages that were included in the Siebel network image for Siebel Web Client are available for selection.
- Select the languages that you want to install, and click Next. You must select at least one language in order to proceed.
To select a language, you click the name of the language in the Available box and then use the arrow controls to move it into the Selected box.
You specify languages to install in order to run Siebel Business Applications using these languages. The files that are specific to the languages chosen in this step will be copied to your computer.
NOTE: You can add languages to an existing installation by running the installer in unattended mode (silent mode). For more information about installing and deploying languages, see Installing and Deploying Siebel Business Applications with Multiple Languages.
The Client Type screen appears.
- Specify the type of Siebel Web Client that you are installing: either Siebel Mobile Web Client or Siebel Developer Web Client. Also specify the client user interface for the Siebel applications that will run on this Siebel client. Select one of the following options, and then click Next:
- (Siebel Mobile Web Client only) In the Remote Server Information screen, specify the name of the Siebel Server on which you are running the Siebel Remote Server components. Then click Next. Go to Step 18.
The Siebel Remote Server components are required for initializing and synchronizing the local database on the Siebel Mobile Web Client computer.
- (Siebel Developer Web Client only) In the Database Server screen, select the type of database server that you are using for Siebel Business Applications. Choose one of the following, and click Next:
- Oracle Database Server
- IBM DB2 UDB for Windows and UNIX
- IBM DB2 UDB for z/OS
NOTE: According on your selection, the Siebel Web Client installer validates that the correct database connectivity software has been installed. If it has not been installed, then you must exit the Siebel Web Client installer, install the required software, and then restart the Siebel Web Client installer.
- (Siebel Developer Web Client only) In the Database Identification screen, enter the following information, and click Next. Specify information for the database that you specified in Step 11:
- (Siebel Developer Web Client only) In the File System Server Information screen, specify the directory path for a network-based Siebel File System by typing it directly or by clicking Browse. Then click Next.
NOTE: For the Siebel File System path, you can use a UNC share name (for example, \\SRV1\siebfile) or a mapped drive (for example, K:\siebelFS). For more information, see File and Directory Naming Conventions. See also Creating the Siebel File System.
- (Siebel Developer Web Client only) In the Remote Server Information screen, click Next to accept the default. (This screen is primarily for Siebel Mobile Web Client.)
- (Siebel Developer Web Client only) In the Enterprise Server Information screen, specify the address of the Siebel Gateway Name Server and the name of the Siebel Enterprise to which this Siebel Developer Web Client will connect for administration. Then click Next.
The Gateway Name Server Address is the network name or the IP address of the computer on which the Siebel Gateway Name Server is installed. To enter a specific port number, append the Gateway Name Server Address string with a colon and the desired port number.
The Enterprise Server name is the name of the Siebel Enterprise under which the Siebel Servers that support the server database were installed.
- (Siebel Developer Web Client only) In the Server Request Broker Information screen, specify the Request Server Name, and click Next.
This value is the name of the Siebel Server on which the Server Request Broker component is operating. This component is used for dynamic assignment and other interactive operations.
- (Siebel Developer Web Client only) In the Search Server Information screen, if you will use a search server, then enter the following for the server computer where the search server operates. Then click Next.
- Search Server Hostname. The default value is localhost.
- Search Server Port Number. The default value is 2048.
NOTE: For system requirements and other information about deploying a search server, see Siebel Search Administration Guide.
The Summary screen appears. This screen displays the location where the Siebel Web Client will be installed.
- Review the information in the Summary screen. Before you proceed, confirm that you have met all of the installation requirements, such as for disk space. Then do one of the following:
- When the browser is displayed and indicates that ActiveX controls have been deployed, close the browser window.
NOTE: The ActiveX controls are used only for applications deployed using high interactivity.
- When the Next button becomes available, the installation is complete. Click Next.
The Finish Installation screen appears. This screen indicates whether the installation was successful and shows the location of the installer log file. You can access this file to review the installation results.
- To close the installer, click Close.
The Siebel Web Client installation is now finished. Siebel application shortcuts are created in the program folder that you specified in Step 7. For more information about these shortcuts, see Siebel Web Client Shortcuts.
- After installing the Siebel Web Client software:
- Repeat this procedure on each computer where you are installing Siebel Web Client.
