Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing Siebel Web Clients and Siebel Tools in Unattended ModeThe installer programs for Siebel Mobile or Developer Web Client and Siebel Tools support an optional unattended installation, which is an installation that has been preconfigured to require no user input when the installation program runs. You can save a response file in a regular installer session. Then you can run the installer at the command line with certain flags appended to the installer command to execute the response file. Together, these tasks constitute installing in unattended mode. You can perform unattended installations for better performance when installing software on multiple client computers. Or, you might perform unattended installations if user input during an installation is not allowed in your environment, as might be the case in some secure environments. An unattended installation prepackages all of the required parameters so that you only have to execute a command to perform the installation. You can use unattended mode to perform a new installation or migration installation of the current release, or to add languages to an existing installation of the current release. To add languages, you must use this method. CAUTION: Unattended installations provide no direct feedback or error notification. Therefore, you must test your settings in a development environment before system-wide deployment in a production environment. It is strongly recommended that you become thoroughly familiar with GUI installation for any Siebel modules for which you intend to perform unattended installation. This topic contains the following information:
Related TopicsGuidelines for Installing Siebel Web Clients and Siebel Tools in Unattended ModeReview the following guidelines for installing Siebel Web Clients and Siebel Tools in unattended mode:
To install Siebel Web Client or Siebel Tools and the specified Siebel language packs using unattended mode, perform the following tasks:
Saving an Installation Response FilePerform the following steps to save an installation response file to be used in an unattended installation of Siebel Web Client or Siebel Tools. NOTE: If you are adding languages to an existing installation of the current release, then do not use this procedure. Instead, follow the procedure in Editing an Oracle-Provided Installation Response File. To save an installation response file
Editing an Oracle-Provided Installation Response FileIf you are adding languages to an existing Siebel Web Client or Siebel Tools installation, then you must edit an Oracle-provided installation response file instead of saving a response file from the installer. For detailed information about the task of adding languages, see Installing and Deploying Additional Languages. Performing an Installation in Unattended ModePerform the following steps to perform an unattended installation of Siebel Web Client or Siebel Tools. First, you must save an installation response file as described in Saving an Installation Response File or prepare an installation response file for adding languages as described in Editing an Oracle-Provided Installation Response File. Then you run the installer command as shown in the following procedure. For detailed information about the task of adding languages, see Installing and Deploying Additional Languages. To perform an installation in unattended mode
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
