Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing Oracle Database XE for the Local Database for Siebel ToolsWhen you install Siebel Innovation Pack 2015, Patchset 5 or later for Siebel Tools, you can install a new local database that uses Oracle Database XE as the database platform. Use the procedure in this topic to install Oracle Database XE and the local database for Siebel Tools. To be able to install this local database, you must have included Oracle XE Local Database, as well as Siebel Tools, when you created the Siebel network image for the patchset release. For more information, see About the Siebel Network Image. The information in this topic complements the existing documentation for installing the applicable Siebel Patchset release. For more information, see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. See also About Siebel CRM Releases. NOTE: With Siebel Innovation Pack 2015, Patchset 5 or later for Siebel Web Client, you can also install the Siebel Sample Database that uses Oracle Database XE. For more information, see Installing the Siebel Sample Database That Uses Oracle Database XE. However, you can install Oracle Database XE for only one of these databases on the same computer: either the local database for Siebel Tools or the sample database for Siebel Web Client. If one of these databases is already installed, then this database's DBF file is overwritten if you install the other database. NOTE: For Siebel Innovation Pack 2015, the local database for Siebel Tools and the sample database for Siebel Mobile Web Client can use either SAP SQL Anywhere or Oracle Database XE. The local database for Siebel Mobile Web Client uses SAP SQL Anywhere. SAP SQL Anywhere is not available for new deployments after September 2015. For more detailed information on how this change affects Siebel Tools and Siebel Remote, see Siebel Release Notes on My Oracle Support for Innovation Pack 2015 (Doc ID 1996273.1). Additional steps are necessary to prepare the local database for use by the Siebel Tools developer. After installing Oracle Database XE and the local database for Siebel Tools, you must run a script to update this database based on your company's database customizations and based on the particular developer who will use this local database. For more information about this task, see Configuring Siebel Business Applications. When you specify to install the local database, Oracle Database XE and the local database are installed silently: no screens are displayed for the Oracle Database XE installer itself. If Oracle Database XE is already installed for any reason, then it is not installed again, but the local database is still installed. If Oracle Database XE was previously installed for any non-Siebel use, then you must uninstall it before proceeding. If you installed the Siebel Patchset release for Siebel Tools, but did not install the local database that uses Oracle Database XE, and you later decide to install this local database, then you can do so by uninstalling this Siebel Patchset release, and then reinstalling it with the local database option selected. NOTE: Oracle Database XE and the local database are not uninstalled when you uninstall the Siebel Tools software, in either a full uninstallation or a rollback uninstallation. For information about uninstalling Oracle Database XE, see Uninstalling Oracle Database XE. Optionally, you can install the Siebel Patchset release for Siebel Tools, with Oracle Database XE, in unattended mode, as described in Installing Siebel Web Clients and Siebel Tools in Unattended Mode. To install and use Oracle Database XE, you must have the 32-bit Oracle database client installed on the developer computer. For more information, and for the version of Oracle Database XE that is installed with Siebel CRM, see the Certifications tab on My Oracle Support. See also the documentation for Oracle Database Express Edition on Oracle Help Center. To install Oracle Database XE for the local database for Siebel Tools
Related TopicsRelated Books |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
