Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing Siebel Tools >
Installing Siebel Tools as a New Installation
Use the following procedure to install Siebel Tools as a new installation for Siebel CRM version 15.0. NOTE: Use this procedure only when Siebel Tools is not already installed. Where an earlier version of Siebel Tools is already installed, you perform a migration installation instead, as described in Installing Siebel Tools as a Migration Installation.
This topic is part of Installing Siebel Tools. This task is a step in:
To install Siebel Tools as a new installation
- Review About Installing the Siebel Web Client or Siebel Tools.
- In Windows Explorer, navigate to the Siebel image location for Siebel CRM version 15.0. Then navigate to the directory where the installer is located. Navigate to
Siebel_Image\Windows\Client\Siebel_Tools\Disk1\install.
In this path, Siebel_Image is the directory for your version-specific Siebel network image, such as C:\Siebel_Install_Image\15.0.0.0.
- To start the Siebel Tools installer, double-click setup.bat.
The Siebel Tools installer displays the Welcome screen.
- Click Next.
A screen appears that prompts for email contact information.
- When prompted for the email address and password corresponding to your My Oracle Support account, click Next. (This information is not used in this context.)
The Select Installation Task screen appears. The New Installation task is selected by default.
- To perform a new installation of Siebel Tools software where no existing installation of Siebel CRM version 8.1.1.x or version 8.2.2.x is present, click Next.
The New Installation Details screen appears.
- Enter a name for your installation and specify the installation location, and then click Next. (Note the installation name and location for future reference.) Note the following:
- The default installation name (Oracle Home Name) is TOOLS_HOME. The value that you specify is used in the parent program folder name for the Siebel Tools client shortcut. (A separate program folder is created for the Oracle Universal Installer software.) If you have an existing installation, then you must specify a new name for the new installation.
- The default installation path (Oracle Home Location) for a new installation is
C:\siebel\15.0.0.0.0\Tools or a similar value. Accept the default path or specify a different location by typing it directly or by clicking Browse. If you have an existing installation, then you must specify a new path for the new installation.
For more information about Oracle home and installation path requirements, see File and Directory Naming Conventions.
The Select Languages screen appears. All of the languages that were included in the Siebel network image for Siebel Tools are available for selection.
- Select the languages that you want to install, and click Next. You must select at least one language in order to proceed.
To select a language, you click the name of the language in the Available box and then use the arrow controls to move it into the Selected box.
You specify languages to install in order to run applications using these languages. The files that are specific to the languages chosen in this step will be copied to your computer.
NOTE: You must install Siebel Tools with the U.S. English (ENU) language pack. You can also install other Siebel language packs.
NOTE: You can add languages to an existing installation by running the installer in unattended mode (silent mode). For more information about installing and deploying languages, see Installing and Deploying Siebel Business Applications with Multiple Languages.
- In the Database Server screen, select the type of database server that you are using for Siebel Business Applications. Choose one of the following, and click Next:
- Oracle Database Server
- IBM DB2 UDB for Windows and UNIX
- IBM DB2 UDB for z/OS
- In the Database Identification screen, enter the following information, and click Next. Specify information for the database that you specified in Step 9:
- In the File System Server Information screen, specify the directory path for a network-based Siebel File System by typing it directly or by clicking Browse. Then click Next.
NOTE: For the Siebel File System path, you can use a UNC share name (for example, \\SRV1\siebfile) or a mapped drive (for example, K:\siebelFS). For more information, see File and Directory Naming Conventions. See also Creating the Siebel File System.
- In the Remote Server Information screen, specify the name of the Siebel Server on which you are running the Siebel Remote Server components. Then click Next.
The Siebel Remote Server components are required for initializing and synchronizing the local database on the Siebel Tools computer.
- In the Enterprise Server Information screen, specify the address of the Siebel Gateway Name Server and the name of the Siebel Enterprise to which Siebel Tools will connect for administration. Then click Next.
The Gateway Name Server Address is the network name or the IP address of the computer on which the Siebel Gateway Name Server is installed. To enter a specific port number, append the Gateway Name Server Address string with a colon and the desired port number.
The Enterprise Server is the name of the Siebel Enterprise under which the Siebel Servers that support the server database were installed.
The Summary screen appears. This screen displays the location where Siebel Tools will be installed.
- Review the information in the Summary screen. Before you proceed, confirm that you have met all of the installation requirements, such as for disk space. Then do one of the following:
- When the Next button becomes available, the installation is complete. Click Next.
The Finish Installation screen appears. This screen indicates whether the installation was successful and shows the location of the installer log file. You can access this file to review the installation results.
- To close the installer, click Close.
Siebel Tools installation is now finished. The Siebel Tools shortcut was created in the program folder that you specified in Step 7.
- After installing the Siebel Tools software:
- Repeat this procedure on each computer where you are installing Siebel Tools.
