Siebel Installation Guide for UNIX > Configuring the RDBMS > Configuring an IBM DB2 Database for Siebel Business ApplicationsThis topic contains guidelines for obtaining optimal performance from an IBM DB2 Database for use with Siebel Business Applications. These guidelines will be useful to a broad segment of customers. Choose values for the parameters described in this guide that reflect conditions in your particular environment. For more information, see IBM DB2 technical documentation. NOTE: In this guide, the terms IBM DB2 or DB2 are often used to refer to the database platform IBM DB2 for Linux, UNIX, and Windows. See also Overview of Database Configuration. When you use IBM DB2, the IBM Data Server Client must be installed on the Siebel Server computer. Verify that the IBM Data Server Client is installed before proceeding. For details, see Siebel Database Upgrade Guide. In addition, the IBM Data Server Runtime Client must be installed on the Siebel Server computer. For IBM DB2 version information, see the Certifications tab on My Oracle Support. NOTE: If your database is IBM DB2 for z/OS, then see Implementing Siebel Business Applications on DB2 for z/OS instead of this chapter. See also the relevant information under Planning RDBMS Installation and Configuration. Guidelines for Configuring an IBM DB2 DatabaseVarious kinds of guidelines are presented for configuring an IBM DB2 database:
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
