Siebel Installation Guide for UNIX > Configuring the RDBMS > Configuring an IBM DB2 Database for Siebel Business Applications > Guidelines for Creating the IBM DB2 DatabaseIf you are installing a database that is to be enabled for Unicode, then you must specify Verify that your data is exported and imported correctly. For Siebel CRM language support, Unicode support, and legacy code page support, see 1513102.1 (Article ID) on My Oracle Support. This topic is part of Configuring an IBM DB2 Database for Siebel Business Applications. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
