Siebel Installation Guide for UNIX > Uninstalling Siebel Business Applications > Process of Removing Configuration Data > Removing the SWSE ConfigurationThe SWSE Configuration Wizard removes the physical configuration from the SWSE. This task removes the eapps.cfg file and removes the Siebel application virtual directories that were created when you applied the SWSE logical profile. This task automatically stops and restarts the Web server. This task is a step in Process of Removing Configuration Data. To remove the SWSE configuration
Related Topics |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
