Siebel Installation Guide for UNIX > Uninstalling Siebel Business Applications > Process of Removing Configuration Data > Removing the Siebel Server ConfigurationThe Siebel Server Configuration Wizard removes Siebel Server configuration data from the Siebel Gateway Name Server and removes the Siebel Server service from the local server computer. NOTE: When removing Siebel Server configuration data using this wizard task, observe all of the documented requirements. Perform this task only if you have uninstalled, or removed all of the applicable configuration data for, all of the installed instances of SWSE that depend on this Siebel Server. Before you uninstall a previously configured instance of Siebel Server, you must perform this task. This task can also be useful in cases that do not involve uninstallation. When you perform this task, the Siebel Gateway Name Server must be running and the Siebel Server service must be stopped. If this Siebel Server was not configured, then this task is not necessary before uninstallation. This task is a step in Process of Removing Configuration Data. To remove the Siebel Server configuration
Related Topics |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
