Siebel Installation Guide for UNIX > Verifying and Troubleshooting Your Installation > Verifying That the Siebel Gateway Name Server Has StartedIf, during configuration, you selected manual start for the Siebel Gateway Name Server, then you must make sure that the Siebel Gateway Name Server is started when you do any of the following:
NOTE: It is recommended that you review the Siebel Gateway Name Server log files, which are found in the Related Topics |
Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
